Changing Settings on the Xero C1 Pro Chronograph
You can change a variety of settings on the Xero® C1 Pro Chronograph. Follow the instructions below to change the settings you want:
- Select SETTINGS > UNITS
- Select a unit of measure and press OK
- Select an option:
- To change the display color during a session, press OK and select DISPLAY COLOR
- To change the display color outside of a session, select SETTINGS > DISPLAY COLOR
- Press OK to cycle through the color options
- Select an option:
- To change the backlight brightness during a session, press OK and select BACKLIGHT
- To change the backlight brightness outside of a session, select SETTINGS > BACKLIGHT
- Press OK to cycle through the brightness levels
- Select SETTINGS > PRO SETTINGS
- PROJECTILE WEIGHT ENTRY: Enables or disables the grain weight entry screen before each session. You can use the grain weight to calculate kinetic energy of your projectile.
- SHOW ALIGNMENT DIAGRAMS: Enables or disables the alignment diagrams that appear before each session.
- DOWNRANGE MODE: Enables and disables a visual alert (flashing screen) when a shot is detected from a unit that is placed down range.
NOTE: An alignment diagram appears the first time you use a new mode even after you disable alignment diagrams.
- Select SETTINGS > LANGUAGE
- Select a language
Clearing device data deletes all shot data and returns all settings to factory default values.
- Select SETTINGS > RESET ALL SETTINGS > YES
