How to Reset an Approach S20
There are two resets that can be performed if you are having issues with an Approach® S20 golf watch not functioning as expected. A forced restart is suggested when the Approach S20 watch is unresponsive or will not power on or off. A master reset is suggested for problems with satellite reception, general functionality issues, or if you want to restore the factory default settings, including language options (all user information other than saved scorecards will be erased with a master reset).
Forced Restart Steps
Press and hold UP/Power button.
Wait up to 30 seconds until device powers on/off.
Release UP/Power button.
The Approach watch will now function properly. If the device is still unresponsive, connect the watch to the computer and then follow the above steps again.
Master Reset Steps
Power off the unit.
Press and hold the Back and OK buttons.
Press the power button until the Garmin logo appears on the screen.
Continue holding Back and OK for 10 seconds.
Release the OK button.
5 seconds after releasing the OK button, release the Back button.
If done properly, the initial setup screen will appear shortly.
The device should now be reset to default factory settings, and should function as expected. Leave the device outside with a clear view of the sky for up to 20 minutes to acquire satellite data.
