Getting the Most Out of Solar Charging With an eTrex Solar
To achieve the best solar charge with an eTrex® Solar outdoor handheld, ensure you are following the tips below.
Tips for Achieving the Best Solar Charge
  • Have the screen facing toward direct sun.
    Solar Charging Facing Sun
  • Avoid covering the solar panel.
    Solar Panel Location
  • Avoid excessive heat, which can prevent charging.
There are some items that are out of your control, but will affect the solar charging. Some have minor effects, while others have a greater effect. Below is a list of what may affect solar charging.1
The Following Can Affect Solar Charging
  • Position of the sun, including time of day and current season2
  • Weather, including clouds, rain, and other weather patterns that may block or obscure the sun
  • Exceeding solar charging temperature thresholds, from 0 to 60°C (from 32 to 140°F)
  • Charging with light sources other than the sun3
  • Whether the eTrex is powered on or off4
View our Video
Can I Use a Screen Protector with an eTrex Solar?
Garmin does not recommend the use of any kind of screen protector as it can reduce the solar intensity received by the eTrex.
If damage occurs to the screen while using a third-party protector, the device will not be covered under Garmin's Warranty.
Checking the Status of Solar Charging
There are a few ways of checking the status of solar charging.
Status Icons
A solar intensity status icon and percentage will be displayed in the top left of the screen.
Solar Intensity Status Icon
With a high enough battery level and solar gain, the device can sustain itself. If so, the battery icon in the top right of the screen will display an infinity symbol.
Infinite Battery Icon
Solar Widget Glance
Hold Back Arrow/Widget Glance List to access the glance loop, then scroll to Solar to view a simple graph for solar intensity over the past 6 hours and the minutes of battery gain achieved through solar charging for the current day.
Widget for Solar
Solar App Pages
Select Solar from the main menu or the glance loop to view additional details.
The first page shows the current solar intensity level, a graph for solar intensity over the past 6 hours, and the hours and minutes of battery gain achieved through solar charging for the current day.
Solar App page 1
Press Down Button to view the second page, which shows battery gain over the past 7 days and the daily average for battery gain.
Solar App page 2
Press Down Button to view the third page, which shows battery gain for each day over the past 7 days.
Solar App page 3
1 The list of what affects solar charging is not an all-encompassing list. Anything that may limit the sunlight from reaching the solar panel on the eTrex will affect solar charging.
2 The farther away from the equator you are, the more seasons will affect charging.
3 While you can use non-natural light, such as from fluorescent lights, to charge your eTrex, solar charging is optimized for the spectrum of sunlight.
4 Solar charging can take place while the eTrex is powered off, and can yield greater charge from the same solar intensity than when the eTrex is powered on.
