D2™ Delta
D2™ Delta PX
D2™ Delta S
D2™ Mach 1 | D2™ Mach 1 Pro
D2™ Mach 2
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
Descent™ Mk3 | Descent™ Mk3i
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® 8 Pro - AMOLED Editions | fēnix® 8 Pro - MicroLED Edition
fēnix® E
Forerunner® 165 Music
Forerunner 255 Music | Forerunner 255S Music
Forerunner 265 | Forerunner 265S
Forerunner 570
Forerunner 645 Music
Forerunner 745
Forerunner 945 | Forerunner 945 LTE
Forerunner 955 | Forerunner 955 Solar
Forerunner 965
Forerunner 970
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 6X Solar
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
quatix® 8
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
Syncing Deezer Music to My Garmin Watch
This article will provide instructions to use the Connect IQ™ app for Deezer on the Garmin® watches listed in the dropdown below. If your device is not listed below see Loading Music to a Garmin Watch.
Requirements
The following are requirements to use the Deezer Connect IQ app on your watch:
The watch must be paired to your smartphone through the Garmin Connect app.
The watch needs to be set up to connect to a Wi-Fi® Network. For help see Setting Up Wi-Fi on a Watch or Edge Cycling Computer.
A Deezer Premium subscription. For help see Deezer's website.
I Meet the Requirements. What's Next?
Follow each step listed below when first setting up the Deezer Music app. Select each section to expand and view instructions on completing each step.
NOTE: You will only need to work through Step 3 from the list below if you are wanting to load additional content to your watch.
Watch this video first to see the process in action - Support: Setting Up Deezer on a Garmin Watch
Select the following link to download the app: Deezer Connect IQ App.
Select
button.If prompted, sign in to your Garmin account.
Select your device to download the app.
Acknowledge any app permission requests.
Sync your device.
To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the key to access the Controls Menu. Select
to syncTo sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the key to access the Controls Menu. Select
to syncTo sync using Garmin Express: Connect the device to your computer using the supplied power/data cable and open Garmin Express. A sync will automatically occur once the device is detected.
The Deezer app will now be installed on your device. Proceed to Step 2.
NOTE: The watch must be able to connect to a previously connected Wi-Fi network. You will also need your smartphone that is paired to your watch. If you have not yet added a Wi-Fi Network to your Garmin Connect app please see: Setting Up or Troubleshooting a Wi-Fi Connection on a Fitness Device.
On the watch, press and hold
DOWN.Press and hold
UP/MENU.Select Music Providers.
Select Deezer.
The watch will search and connect to Wi-Fi.
Once connected, the watch will display a message to open the Garmin Connect app to sign in. At the same time, your smartphone should display a similar notification.
Acknowledge message on the phone which will take you to Deezer. Depending on whether you have an account, the login process will be as follows:
Existing Deezer Users: Enter your login details and select Log In.
New to Deezer: Select the Register here option and follow the steps to create your account.
If prompted, enter credit card details to complete the process.
From your Deezer account, create playlists. Saved playlists will display as optional music to sync. For more information see Deezer Support.
DOWN.Press and hold
Select Deezer.
Select Add Music and Podcasts.
Select My Playlists.
Choose playlists you want to sync to your watch.
Select Done.
Press
BACK and select Yes to "Start music sync now?".
