Wireless Map and Software Update Instructions
Your Garmin fleet 770, 780, and 790 can download map updates over the air via an internet-enabled Wi-fi connection.
To successfully complete a Wi-Fi update, a wireless connection to home high-speed internet (Fiber, Cable, DSL, etc.) is required. Due to the size of a map update, connections with data caps or restrictions should not be used. Slower connections (satellite, fixed wireless, dial-up, etc.) and mobile broadband (MiFi, AirCard, cell phone tethering, etc.) should not be used.
The device must be plugged into power to perform the update. See External Power Options for Wireless Updates for more info.
NOTE: See Not Enough Free Space for a Wireless Update if your device states there is not enough space for the wireless update.
View the Following Video to Learn about Map and Software Updates:
To Check For and Install Both Software and Map Updates on These Devices:
1. Plug the device into a power source
2. Touch
3. Touch About Device
3. Touch System Updates
4. If prompted, touch Access Wi-Fi Settings. If your device is already connected to a wireless network, skip to step 9
5. If prompted, enable Wi-Fi by touching the toggle switch and changing it from Off to
On
6. Select the desired wireless network. A network labeled Garmin is shown as an example, but you may select your personal wireless network.
7. If necessary, enter the password for the network
The device should then connect to the network, and the network will be added to the list of saved networks. The device will reconnect to this network automatically when it is within range.
8. Press the back arrow
9. The device will check for any available updates over a Wi-Fi network. If updates are available, they will be displayed on this page.
Press Map to view information about and start the map update, or Software to view information about and start the software update.
To begin downloading all updates, press Download, then OK.
Note: The device will be unusable until the updates complete.
If the device encounters any problems with the wireless update, see Troubleshooting Wireless Updates on an Automotive Device.
Fleet partners and end-consumers can also update their maps using Garmin Express. See Updating Automotive Maps and Software with Garmin Express.
