NOTE: A Windows computer must be used for these steps. See
Automotive Device Compatibility with Garmin Mac Applications on macOS for more info.
A device restart will be required before performing the steps below.
- Press and hold the power button for 2-3 seconds, then touch Power Off.
- Press the power button to turn the device back on.
1. Plug the dēzl into the computer once the device gets to the main menu (Where To?/View Map)
2. Hold down the Windows key + E on the keyboard
Click This PC in the new window if using Windows 10 or newer.
3. Double-click the drive labeled with the device name
- Windows 10 or newer: the drive will be listed under Devices and Drives
- Windows 7 and 8: the drive may be listed under Devices with Removable Storage or Portable Devices
4. Double-click Internal Storage
5. Open the Android folder
6. Open the data folder
7. Open the com.garmin.pnd.eldapp folder
8. Open the files folder
9. Open the Reports folder
10. Open the HOSExports folder
11. The log files should now appear in the folder
See Exported IFTA or Saved RODS Reports Not Found in the Folder When Connected to a Computer if reports are missing.
