Tacx Temperature Ranges
Operational Temperature Range
The temperature range for using the device is 0 C° to 55 C° (32 F° to 131 F°).
NOTE: If you are using the Tacx Flow Smart Trainer and you are getting a red flashing light, see: The Light on My Tacx Flow Smart Trainer Is Flashing Red After an Intensive Workout
Storage Temperature Range
You can store the device in temperatures from -22 C° to 55 C° (-7 F° to 131 F° ).
IMPORTANT: If you store your trainer in a temperature under 0 C° you will need to move it to a room above that temperature and give it a minimum of 12 hours to warm up before using it.
