Using TracBack on the GPSMAP 79 Series
The TracBack feature allows the user to navigate back along the previously recorded activity or track.
Recording an activity or a track is a primary function of a Garmin handheld when powered on and connected to satellites. Allowing the user to begin the activity when powering on the device.
The GPSMAP 79 series records this using Activity FIT files. These smaller file types allow the unit to record and store significantly more files.
Recording Controls allow the user to manage the recording, so a TracBack is most helpful. For steps, see Related.
Performing a TracBack
NOTE: A TracBack can only be performed using the current track or activity. If a saved or archived track or activity is chosen, the TracBack option will not appear.
  1. Press MENU twice to access the main menu
  2. Select Recording Controls
  3. Press Left Arrow or Right Arrowto reach View Map
    The current activity will be displayed on the map
  4. Press ENTER to select TracBack
The handheld will then begin to navigate back to the start of the trip along the same path. The Map or Compass page will also help navigate.
Related
