Avoiding Propane-Restricted Roads on a Camper / RV 785
IMPORTANT: Propane tanks added should be portable propane tanks only. For more information see Propane Restrictions on a Camper/RV Device.
Camper/RV devices have the ability to route away from roads that prohibit vehicles carrying portable propane tanks. Always follow posted regulations and road signs to ensure compliance with any existing propane restrictions.
To Add Portable Propane Tanks to an Existing Vehicle Profile:
- Touch Settings
- Touch Navigation
- Touch Vehicle Profile
- Select the desired profile
- If necessary, create a new profile by pressing
in the upper left corner
- Portable Propane tanks may not be added in Car mode
- Touch the
portable propane tank icon in the upper right corner
- Touch Add Tank
- Enter the weight of the tank carried
- Touch Save
- Repeat steps 6-8 as needed.
The portable propane tank settings will now be saved.
To Edit a Saved Portable Propane Tank:
- Touch Settings
- Touch Navigation
- Touch the
- The number inside this icon indicated the number of portable propane tanks in the selected profile
- Touch the portable propane tank you wish to edit
- Touch the bar at the top to edit the name
- Touch Capacity to edit the weight
- Touch Remove Tank to delete the portable propane tank
The portable propane tank settings will now be changed.
