Sending a Message with the Garmin Explore App
The Garmin Explore™ app can be paired and used with a compatible inReach® device to send messages to SMS numbers and email addresses that are either saved as contacts in the phone, saved directly in the app, or manually entered.
IMPORTANT: The Garmin Explore app must be paired and connected to an inReach device to send a message. The message icon appears once the inReach device is paired and has an active subscription.
Sending a Message Using the Garmin Explore App
  1. Open the Garmin Explore app.
  2. Touch Message Icon Messages on the bottom of the app.
  3. Touch Pencil New Message.
  4. Select or type the desired recipient using one of the available methods:
    • Select Plus Symbol in a Circle (iOS) or Plus Symbol With Head and Shoulders (Android) to select one of your saved inReach contacts. From this page you can also select Plus Icon to create a new contact or import system contacts.
    • Tap the To: field, begin typing a contact name, then select the direct contact method from the list that appears.
    • Tap the To: field and manually enter a phone number, email address, or inReach address.
  5. Repeat step 4 for any additional recipient(s) you wish to add to the message.
  6. Compose the message.
  7. Select Send Icon to send the message.
Related
