Missing Radio or Weather Information on Garmin Chartplotter
Some Garmin chartplotters can receive satellite radio and weather information from SiriusXM if networked with a GDL or GXM antenna. If there is no radio or weather information on the chartplotter, check the following:
If the antenna is connected to a power and audio module, check the module's status light:
Light BehaviorMeaning
Green solid lightBoth the antenna and module are powered and detected.
Red solid lightThe module is receiving power, but the antenna is not detected or powered.
flashing red LEDRed flashing lightThere is a problem with the module. Update the system software and check the connections between the module, power source, and antenna. If the module continues to flash red, replace the module.
No light (turned off)The module is receiving no or insufficient power.
