inReach SE+/Explorer+ Firmware Update Release Notes
The inReach SE+/Explorer+ firmware updates provide inReach satellite communicators with new features and capabilities. For instructions on updating to the latest firmware, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync. Firmware updates must be done via a computer and cannot be done using the Earthmate app.
Firmware 5.6 - Released September 3, 2024
  • Removed social contacts: Facebook and Twitter
  • Fixed interaction between Unsent Items page and power button
Firmware 5.5 - Released July 20, 2023
Fixes
  • Fixed issue with potentially displaying incorrect map scale units on detail views
Firmware 5.2 - Released September 2, 2021
Fixes
  • Fixed possible issue with sending forms messages for professional users
Firmware 5.1 - Released August 5, 2021
New
  • Support for forwarding text messages
  • Support for updating the address of a message received from an unknown address
  • Support for retrying weather requests
Fixes
  • Displaying incorrect UTM zone letters in the southern hemisphere
  • Entering or editing UTM coordinates that are near the equator
  • Data use counts not resetting at the start of a new year
  • Down arrow press moving too quickly to the done button when composing a message
  • Map not drawing properly after marking a waypoint
  • Check page not updating properly when a check completes
Firmware 4.2 - Released April 24, 2020
New
  • Removed power on confirmation screen
Fixes
  • Improved display of weather icons
  • Improved performance when receiving multiple inReach messages
  • Applied Bluetooth security patches
  • Adjusted default mail check behavior for professional customers
  • Fixed problem with creation dates for edited waypoints
  • Fixed editing and displaying UTM/UPS and USNG/MGRS coordinates
  • Fixed incorrect tracking intervals after checking for a Plan Update
Firmware 4.1 - Released September 2018
  • Changes to support manufacturing (Units built prior to 9/18 will not have this firmware version and do not require it)
Firmware 4.0 - Released August 10, 2018
New
  • Added new SOS info message when a user declares SOS.  This will show the user and emergency services if the inReach or a paired app declared the SOS
Fixes
  • Improved Mailbox Check performance when device is idle
Firmware 3.8 - Released November 29th, 2017
New
  • SMS and Email linking within incoming messages
Fixes
  • Improved display of Parcel data
  • Backlight remains on during device activation
  • Improvements to magnetic course
  • Improvements to display of GPS Track Log on Map page
  • Improvements to font size for high speeds
  • Corrected long waypoint name issue
  • Improvements to unsent message dialog on shutdown
  • Notification text improvements
Firmware 3.6 - Released May 22nd, 2017
Fixes
  • Corrected possible issue with Tracking Intervals not showing properly after an update
  • Corrected an intermittent issue where the Skip Activation button did not sometimes appear
Firmware 3.5 - Released April 28th, 2017
New
  • Enable future firmware updates to be done with the Earthmate app over Bluetooth connection
  • Added ability for users to skip activation prompts on first power up
  • Users can now turn off map data that was preloaded on the device
  • Added Barometer to the list of available Info Fields
  • Added ability to switch between True and Magnetic North to the Bearing Info Field
Fixes
  • Various improvements to multiple language support
  • Improved back light behavior during activation screens
  • Prevent possible issue when utilizing hundreds of address codes
  • Route lines on the Map page will display more reliably
  • Fixed rare issue with Weather forecasts being marked as "unread" after you viewed them
Firmware 3.4 - Released February 6th, 2017
New
  • Ability to reorder all of the icons on the Home Screen
  • Added Customizable Data Fields on the Map, Compass, and Trip Info pages
  • Improved Message notification system for new messages and alerts
  • Ability to navigate toward any point selected from the map
  • Improved map scanning and loading performance for Explorer+ devices
  • Multiple improvements to the Weather page User Interface
  • Improved power on behavior for better user feedback
  • Auto backlight is now brighter at default settings
  • Added support for additional maps types
  • Various small tweaks throughout the UI
Fixes
  • Improved Route display on Map page
  • Improved language selection
  • Improved device activation process
  • Improved Dark Mode display
  • Improved Waypoint name display process
  • Improved Bluetooth
Related
