SD Memory Card Compatibility for Garmin Dash Cam 45 and Garmin Dash Cam 65W
Garmin Dash Cams require an SD card to record video or take pictures because the device does not have any internal memory for storing files.
SD Card specifications for Garmin Dash Cam™ 45 and Garmin Dash Cam™ 65W:
Specifications
Minimum CapacityMaximum CapacityCard TypesSpeed Class
4 GB64 GB
microSD,
microSDHC,
microSDXC
Class 10 (or higher) is required
SD/microSD cards can be purchased from Garmin or other retailers.
SD memory cards wear out after they are overwritten a large number of times.
  • Your device detects memory card errors automatically and alerts you when it is time to format or replace your memory card.
To help extend the useful life of your SD card, Garmin recommends the following:
  • Back up saved footage and format the memory card at least once every 6 months.
  • Replace the memory card periodically due to the dash camera recording continuously.
  • Turn off the device when your vehicle is not in use to prevent the dash camera from recording unneeded footage.
  • Use a memory card with a higher storage capacity.
    • Higher-capacity memory cards are overwritten less frequently and will usually last longer.
  • Use a high-quality memory card with a speed rating of class 10 or higher.
  • Purchase your replacement memory card from a high-quality manufacturer and a reputable vendor.
The Following SD cards have been Tested and Verified to work with the Garmin Dash Cam 45 and Garmin Dash Cam 65W.
SD cards not listed may or may not work with your device.  Class 10 is required.
Compatibility
SD Card BrandSpecsSize
ADATAUHS-I16GB and 32GB
TranscendHigh Endurance16GB and 32GB
ToshibaExceria UHS-I16GB and 32GB
KingstonEVERPRO UHS-I U132GB
