Avoiding Missed Shots and False Strokes with Approach CT10
When using CT10 sensor for club stat tracking, following some best practices will ensure that the device will provide the most accurate information possible. Here are some of the best practices to use to ensure that the device is ready to use and provide the most accurate readings.
Best Practices
- Complete a full swing - Make sure to follow through, especially on shorter putts
- Carry clubs with grips pointed down
- Avoid carrying multiple clubs in the same hand - This will avoid the clubs clanking together against each, causing false stroke readings
- Avoid mishandling clubs - Avoid dropping clubs on the ground, tapping the grounds, or fixing divots
- Practice Swings - Take practice swings at the same location as the ball
Following these practices will maximize the accuracy when club tracking.
