The Floors Climbed Feature Is Not Accurate on My Watch
This feature uses the built in barometric altimeter sensor to detect a change in air pressure which occurs when you climb or descend a flight of stairs or a hill.
How Do I Get Credit?
Credit is given for a consecutive increase of 10 feet (3 meters) in elevation with a grade of 10% or higher while walking or running. This includes during a recorded activity, whether indoor or outdoor.
I'm Not Getting Enough Credit
Holding onto a handrail or skipping stairs as you climb can affect credit due a reduced amount of swing in your arm. To earn credit, you must be moving forward and up which would exclude riding an elevator or using exercise equipment.
I'm Getting Too Much Credit
Situations that can cause excessive credit include a significant change in pressure such as a strong pressure system or walking into a warm building on a cold day. Walking near exit doors when it is cold outside may also trigger extra credit. Walking outside on a windy day with the watch exposed to the wind can also result in false credit.
Clean the Barometer Port on the Device
If the small portholes on the back or side of the watch are obstructed, it may interfere with the ability for the watch to measure elevation properly. To clean the sensor, locate the port on the back or side of the watch. You can rinse the port with water or you can also soak the watch in water for 5 minutes, agitating it every minute to help breakdown and remove any debris, such as sweat crystals or skin cells. After cleaning and/or soaking, allow the watch to dry completely.
IMPORTANT: Do not stick anything into the holes or use canned air as this can result in damage to the sensor.
Locate the Barometer Port Hole
Approach® S70 Watches
Approach S70 Baro Port
D2™ Mach 1 Watch
D2 Mach 1 Baro Port
Descent™ G1 | Descent™ G1 Solar Watches
Image of Descent Barometer Port
Enduro™ Watch | Enduro™ 2 Watch
Image of Enduro Barometer Port
fēnix® Watch and All Other Models Within the fēnix Series
Image of fēnix Barometer Port
Forerunner® 645 | Forerunner® 645 Music Watches
Image of Forerunner 645 Barometer Port
Forerunner® 165 | Forerunner® 165 Music | Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music | Forerunner® 265 | Forerunner® 265S | Forerunner® 745 | Forerunner® 935 | Forerunner® 945 | Forerunner® 945 LTE | Forerunner® 955 | Forerunner® 955 Solar | Forerunner® 965 Watches
Image of Forerunner 935 Barometer Port
Instinct® Watch and All Other Models Within the Instinct Series
Image of Instinct Barometer Port
MARQ® Driver Watch and All Other Models in the MARQ Collection
Image of MARQ Barometer Port
MARQ® Golfer (Gen 2) Watch and All Other Models in the MARQ (Gen 2) Collection
MARQBaroPort
tactix® Watch and All Other Models Within the tactix Series
Image of tactix Barometer Port
vívoactive® HR Watch
Image of vivoactive HR Barometer Port
vívoactive® 3 Watch
Image of vivoactive 3 Barometer Port
vívoactive® 3 Music Watch
Image of vivoactive 3 Music Barometer Port
Venu® | vívoactive® 4 | vívoactive® 4S | Captain Marvel | First Avenger Legacy Hero | Darth Vader™ | Rey™ Legacy Saga Watches
Image of vivoactive 4 Barometer Port
Venu® 2 Plus Watch
Green arrow pointing at Venu 2 Plus barometer port
Venu® 2 | Venu® 2S Watches
venu 2 baro
Venu® 3 | Venu® 3S Watches
Photo of Venu 3 baro hole
vívomove® HR Watch
Image of vivomove HR Barometer Port
vívomove® 3 | vívomove® 3S | vívomove® Luxe | vívomove® Style Watches
Image of vivomove 3 Barometer Port
vívomove® Trend Watch
NOTE: Step 1 and 2 are demonstrating that you must remove the quick-release band in order to access the barometer port on this model.
Watch photo with orange arrow displaying Barometer Port
vívosmart® HR | vívosmart® HR+ Watches
Image of vivosmart HR Barometer Port
vívosmart® 3 Watch
Image of vivosmart 3 Barometer Port
vívosmart® 4 Watch
Image of vivosmart 4 Barometer Port
vívosport® Watch
Image of vivosport Barometer Port
Calibrate the Barometric Altimeter
This occurs automatically when you follow these steps:
NOTE: This does not apply to devices that use Connected GPS.
  1. While outdoors, select an outdoor activity profile.
  2. Allow the watch to acquire a GPS signal.
  3. Wait an additional 30 seconds after acquiring a signal before starting or exiting the activity. No message will appear but allowing the extra time will complete the calibration process.
