Using the Rock 'n Roller Switch on a Colorado Series Handheld
The Rock 'n Roller switch allows you to navigate and select menu items.
Using the Rock ‘n Roller on a Colorado® Outdoor Handheld
- Rotate the Rock ‘n Roller to move up and down menu lists. You can also move through the lists by pressing up, down, left, and right.
- Press ENTER to make all selections on the Colorado.
- Press up, down, left, and right on the Rock ‘n Roller to pan the map.
