Below is a list of articles that will help you get started with, and get the most out of, your new Enduro™ watch.
How Do I Get Started?
You can follow the below instructions for the process of setting up your Enduro watch.
Before getting started, we recommend that you fully charge your Enduro watch. See Charging the Device to learn how.
1. Power on the Enduro watch by holding Light | Click here to learn about the buttons
2. Choose your language by scrolling through the list, use with the UP to select your language |
3. Pair your watch with your smartphone following the on-screen instructions (optional) | Click here for help with Bluetooth pairing |
4. The next steps allow you to set your user preferences, simply follow the on screen prompts in the Garmin Connect App |
5. Select your favorite types of activities to finish setup (optional) | Click here to learn how to set your favorite activities- Locate your activities by using the Up or Down buttons to scroll through the list
- Press Start/Stop to select the activities
- Use the Down until you see Done on the screen
- Press Start/Stop to save your selections
- To start using activities, see How to Start an Activity
TIP: If you want add activities later, see How to Add an Activity to the Enduro
Other Articles You Might Find Useful
