Route and via Points for Garmin Mode Color Handheld Device
The color handheld devices can store up to 50 routes with each route able to store 250 points each. However, if the routing option is set to Follow Road, then the route can only contain 50 points.
In this scenario, if more than 50 points are within the route, an error message will appear when starting route navigation. The route will need to be recreated with fewer points before the device will allow navigation.
