Install or Install All installs updates to software and any maps that are currently installed to your device.
View Details shows details on the specific updates (software, GPS, or map).
Map Details shows what maps are currently installed to your device.
Manage Maps allows you to add or remove maps from the device.
Managing Maps on Garmin Devices With Garmin Express
The Manage Maps feature allows you to install additional map regions on select Garmin® watches and Edge® cycling computers. It also allows you to view, update, remove, or add maps.
See below for a list of Compatible Devices .
Managing Maps With Garmin Express™ Software
If this is your first time using a computer with your device, you will need to download and install our Garmin Express software. For information on downloading and installing Garmin Express software, see - How Do I Install Garmin Express?.
Connect your device to the computer with the Garmin branded USB charging cable.
Launch Garmin Express.
Select your device.
If this is your first time using Garmin Express, see - Adding and Removing Devices in Garmin Express.
Garmin Express will then display available updates. If it says you are up to date, then the software and maps currently installed to your device are on the most current version(s).
Ensure that your computer has enough disk space to download and temporarily store updates and/or map files.
Select Manage Maps to add or remove maps from your device.
Check or uncheck maps to add or remove them from your device.
Select Apply Changes.
Review and accept any prompts for Terms and Conditions or Important Notes.
Once Garmin Express finishes applying the changes, disconnect your device from the computer.
Compatible Devices
See a dropdown below to see devices compatible with this feature.
Approach S70 | Approach S70 - TaylorMade® Edition
See Related Content at the bottom of this page for more information on using the Map Manager on an Approach watch.
D2 Mach 1 | D2 Mach 1 Pro
Descent Mk3 | Descent Mk3i
- Descent X50i
Edge 1030 Plus
Edge 540 | Edge 540 Solar
Edge 840 | Edge 840 Solar
Edge 1040 | Edge 1040 Solar
Edge 1050
Edge Explore 2
Edge MTB
For other Edge models, refer to Installing Maps on an Edge Without an SD Card.
Enduro 2
- Enduro 3
epix (Gen 2) - Standard Edition | epix (Gen 2) - Sapphire Edition | epix (Gen 2) - Porsche Edition
epix Pro (Gen 2) - Standard Edition| epix Pro (Gen 2) - Sapphire Edition
fēnix 7S - Standard Edition | fēnix 7S - Solar Edition | fēnix 7S - Sapphire Solar Edition
fēnix 7 - Standard Edition | fēnix 7 - Solar Edition | fēnix 7 - Sapphire Solar Edition
fēnix 7X - Solar Edition | fēnix 7X - Sapphire Solar Edition
fēnix 7S Pro - Solar Edition | fēnix 7S Pro - Sapphire Solar Edition
fēnix 7 Pro - Solar Edition | fēnix 7 Pro - Sapphire Solar Edition
fēnix 7X Pro - Solar Edition | fēnix 7X Pro - Sapphire Solar Edition
fēnix 8 - AMOLED Edition | fēnix 8 - Solar Edition
fēnix E
Forerunner 955 | Forerunner 955 Solar
Forerunner 965
Forerunner 970
MARQ Adventurer (Gen 2)
MARQ Adventurer (Gen 2) - Damascus Steel Edition
MARQ Athlete (Gen 2)
MARQ Athlete (Gen 2) - Carbon Edition
MARQ Athlete (Gen 2) - Performance Edition
MARQ Aviator (Gen 2)
MARQ Captain (Gen 2)
MARQ Commander (Gen 2) - Carbon Edition
MARQ Golfer (Gen 2)
MARQ Golfer (Gen 2) - Carbon Edition
quatix 7 - Standard Edition | quatix 7 - Sapphire Edition | quatix 7X - Solar Edition
- quatix 7 Pro
tactix 7 - AMOLED | tactix 7 - Standard Edition | tactix 7 - Pro Edition | tactix 7 - Pro Ballistics Editions
- tactix 8 - AMOLED | tactix® 8 - Solar
- Venu® X1
