Instructions to Sync Amazon Music Content to the Descent Mk2 Series
This article will provide instructions to use the Connect IQ™ app for Amazon Music on the Descent™ Mk2, Descent™ Mk2S, and Descent™ Mk2i dive watches.
Requirements
The following are requirements to use the Connect IQ™ app for Amazon Music on your watch:
  • Watch must be paired to your smartphone through the Garmin Connect™ app.
  • Watch must be set up to connect to a Wi-Fi network. For help, see - Adding Wi-Fi Networks to Compatible Watches.
  • An Amazon Prime or Amazon Music Unlimited account is required. For help, see - What is the Difference Between Prime Music and Amazon Music Unlimited?
  • You must be the Amazon Prime primary account holder. A family member sharing the benefit of Amazon Prime Music will not work.
  • Secure Clock: This feature is used to synchronize the time on your watch. If you have never used the GPS on your watch, or if the battery has been completely discharged recently, you may be prompted to enable GPS after accessing the Amazon Music app. GPS can be enabled by choosing an outdoor activity.
  • The app works in the United States, Canada, Mexico, Brazil, United Kingdom, France, Italy, Germany, Austria, Spain, India, Australia, New Zealand, and Japan.
I Meet the Requirements. What Do I Do Next?
The three steps listed below need to be completed when first setting up the Amazon Music app with your watch. Once complete, you will only need to follow the third step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Connect IQ App for Amazon Music
  1. Select the following link to download the app: Connect IQ app for Amazon Music
  2. Select Blue Download Buttonbutton.
  3. If prompted, sign into your Garmin® account.
  4. Select your watch to download the app.
  5. Acknowledge any app permission requests.
  6. A message should indicate that the app will be installed during the next sync. If this does not occur automatically, sync your watch manually:
    • To sync via Bluetooth: Be in range of your paired smartphone, and open the Garmin Connect app. Select blue sync arrows on the My Day page to sync.
    • To sync via Wi-Fi: Be in range of your previously set up Wi-Fi network, and hold the Menu button on the watch. Scroll down and select Wi-Fi; if you do not see Wi-Fi listed, you may need to select Settings or Connectivity first and then select Wi-Fi. Select Wi-Fi Sync or Connect to Wi-Fi and wait while the watch connects to Wi-Fi and syncs.
    • To sync using the Garmin Express™ software: Connect the watch to a computer using the supplied power/data cable. Open the Garmin Express program. A sync will automatically occur once the watch is detected.
Once the sync is complete, the Amazon Music app will be installed onto your watch. You can also install Connect IQ apps to your watch by following the instructions in Installing Connect IQ Content Using the Connect IQ Store App. After the app installs, you are ready to move to Step 2.
Step 2: Set up the Connect IQ App for Amazon Music
Once the app is installed, you will be prompted on the watch to continue setup.
  1. Hold UP/MENU to access the menu.
  2. Scroll to or select Settings.
  3. Select Music.
  4. Select Music Providers.
  5. Select Amazon Music.
  6. Press the UP/MENU key.
  7. Select Amazon Music Icon (Amazon Music Icon).
  8. The screen should prompt you to visit amazon.com/us/code. The code provided on the watch will tie it to your Amazon account. Use a mobile device or personal computer to complete this step. Once completed, allow up to a few minutes for the watch to proceed to the main menu.
You are ready to move to Step 3.
Step 3: Selecting and Syncing Content to the Watch
NOTE: Your watch must connect to your Wi-Fi network to download content from Amazon Music.
  2. Select or scroll to Settings.
  3. Select Music.
  4. SelectAmazon Music Icon(Amazon Music Icon).
  5. Select Browse.
  6. Choose a category then choose the content you want to sync to your watch.
At this point, the watch will connect to your Wi-Fi network. We recommend plugging the watch into an outlet near the Wi-Fi router for the best results.
After listening to your music, you can report all songs played to Amazon Music by selecting the Amazon Music icon from the Music Widget and then selecting Sync. You can also trigger a sync by plugging the watch in to charge.
Related
