Fusion® MS-RA70NSX Manual Software Updates
Fusion® MS-RA70NSX Marine Stereo software version 1.1.60
as of February 21, 2022
Download (495 KB)
View installation instructions
Notes:
- This firmware release also contains updates for NRX remote controls.
- NRX Series Remote 1.02.78
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- Accessory software updates (MS-NRX Series): Once the stereo is updated the connected accessory MUST be updated from the update menu to be compatible with your Fusion Entertainment System.
Change History
Changes made from version to 1.1:
- General bug fixes and improvements
Installation Instructions
- To check the installed version of software go to the About Screen in the Settings Menu.
- Download the required zip file to your PC/Laptop.
- Extract the Update folder to a USB flash drive.
- Connect the USB Flash Drive to the products USB Port.
- Select the Update feature in the settings menu on the product or via the BT app/F-Link supported MFD or NRX series remote.
- The Update takes about 1 minute and the 'Success' prompt will be displayed once the update is complete.
- The accessory software updates (MS-NRX Series) are imbedded in the MS-RA70NSX update. Once the update has been installed in the MS-RA70NSX, the connected accessory MUST be updated from the Update menu screen in the Settings Menu to be compatible with your Fusion Entertainment System.
