You Do Not Have Permission to Complete This Action Error Message for the Garmin Golf App
If you are signed into different accounts in the Garmin Golf™ app and the Garmin Connect™ app on an iOS mobile device, you can get an error message that you do not have permission to view scorecards, and scorecards may not appear. The error message usually occurs when you select a scorecard in the Garmin Connect app which takes you to the Garmin Golf app to view them.
Garmin Golf App Permission Error Message
You will need to sign out of the Garmin Golf app, then sign into the correct account to fix the issue.
Switching to the Correct Account for the Garmin Golf App
NOTE: Information from your account will not be lost when signing out.
  1. Open the Garmin Golf app.
  2. Select Profile.
  3. Select your name.
  4. Select Log Out.
    NOTE:
    If you are signed into another Garmin app (such as the Garmin Connect app) on your phone, select Switch Accounts to complete the sign out process.
  5. Select Sign In
  6. Sign into the correct account
You should now see your scorecards in the Garmin Golf app. See Related for troubleshooting other scorecard syncing issues.
Related
