Using the Map Page on the Rino 600 Series
represents your location on the map. As you travel, the
moves. When you are navigating to a destination, your route is marked with a magenta line.
Using the Map
You can use the map to navigate an active route.
From the main menu, select Map.
Hold the device level.
Follow
to your destination.
