vívofit jr. 3 Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the table below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only on the vívofit® jr. 3 watch.
The following usage assumptions were used to determine the battery life for the vívofit jr. 3. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
vívofit jr 3 - Default Usage Assumptions
Minutes of Stopwatch Usage per Day1
15
Minutes of Timed Activity Usage per Week130
Minutes of Task Timer Usage per Day110
Number of Syncs per Day2
Minutes of Interaction with the Device per Day (e.g. reviewing step count or active minute pages)2
Battery LifeUp to 1 year
1 The usage of the stopwatch, task timers, and timed activities have the largest impact on battery life. Usage of these features beyond what is stated in the table above may result in reduced battery life.
