Correcting Low Volume on Automotive Devices
If you are having trouble hearing the sound coming from the automotive device you will first want to make sure that the volume or master volume is set to an audible level.
To check the Volume or Master Volume:
- Touch the Volume icon on the Where To? View Map screen
- Confirm that the volume is set to the desired level and it is not muted
If the master volume is turned up and the volume is still low, check the volume levels within the mixer to make sure they are set to an audible level.
To view the device's volume:
- Touch the Wrench icon, slider icon, or menu button (three horizontal lines)1
- Confirm the desired volume for Navigation, media, and/or Phone
- Touch Back to return to Where To? View Map screen
The volume level should now be set to the desired level.
1This icon will only be available after a phone has been paired to the device.
