Viewing More Map Data Fields on a dēzl™ 760
Your automotive device has a map setting which allows you to view more data fields (speed, direction, time, elevation) when you are on the navigation screen. By default, there are only two data fields at the bottom of the screen, at least one of which is customizable.
Change the Dashboard Display To View More Data Fields
- Touch Settings
- Touch Map & Vehicle
- Touch Dashboards
Selecting the arrows to the left and right of the screen will toggle between the available dashboards. Press Save on the preferred dashboard.
The device will now display more data fields on the navigation screen. Most of these data fields will be customizable by touching each field. The dēzl™ 760 also has options for RV and Truck. Select the vehicle mode you would like to edit. Repeat these steps for each vehicle mode.
