Customizing the Data Fields Displayed on a GPSMAP 4xx or 5xx Series Device
There are only four data fields that can be customized on the GPSMAP 4xx or 5xx series chartplotters/sounders. These data fields will appear in each of the four corners of the screen.
To customize the information displayed in these data fields, please follow these instructions:
  1. From the home menu, highlight Charts and press the Select button
  2. Highlight Navigation Charts and press the Select button
  3. Press the Menu button
  4. Highlight Data Bars and press the Select button
  5. Highlight Cruising and press the Select button
  6. Highlight Data Bar Setup and press the Select button
  7. Choose one of the four corners in which the data will be displayed and press the Select button
  8. Choose the data that is desired to be displayed and press the Select button
  9. Highlight Yes or No to apply this same data field to all other screens like Sonar and press the Select button
  10. Press Menu button
  11. Highlight On and press the Select button
The chosen information should now be displayed in the data field on your device.
If the device does not have the Data Bars option, the internal operating system of the device may need to be updated to the latest version. Please review the Related Content.
