Using the Delta Canine Remote with Multiple Collars
When using the Garmin Canine™ remote with multiple collars, the remote will activate all paired collars. To avoid this, you will want to remove the currently paired collar from the remote prior to adding another collar. Adding and removing collars from the remote must all be done using the Garmin Canine app. Instructions can be found in the related content below.
