You are viewing an article that is not available in your currently selected language. You can choose another one below.
Deleting Garmin Explore App Data on the Overlander
The Garmin Explore™ website is an intermediary tool for creating, deleting and transferring data to and from the Overlander® GPS navigator.
At times it may not be possible to access the Garmin Explore website to delete data from the Overlander, in which case, data can be deleted directly from the Overlander instead.
For deleting data via the Garmin Explore website, see Deleting Data and Messages from the Garmin Explore Website.
Deleting Data from the Overlander:
- Select Explore from the main screen
- Select Library
- Select Activities, Waypoints, Routes or Tracks
- Select Edit in the top right corner
- Select the checkbox(s) for the data to be deleted
- Select Delete at the bottom of the page
- Select Delete again
The selected data should now be deleted.
