Sharing Your Garmin Connect Data With Apple Health
If you enable sharing, Apple Health can receive the following data from your Garmin Connect™ account:
NOTICE: The Garmin Connect™ app cannot receive any data from Apple Health or an Apple Watch. Data sent to Apple Health also depends on what options are enabled in Health and what types of data are supported by the connected Garmin device.
Active Energy
Body Fat Percentage
Body Mass Index
Flights Climbed
Heart Rate
All-day heart rate recorded by your Garmin watch will be displayed in Apple Health. Time activities however, will only display high and low heart rate values. This may result in heart rate graphs for activities from Connect showing as "Chart Unavailable" in the Apple Activity app.
Resting Energy
Sleep Analysis
Steps
Walking + Running Distance
Water
Weight
Workouts (activities uploaded to Garmin Connect)
Any associated GPS track will NOT be written to Apple Health
Once Garmin Connect sharing is enabled in Apple Health, data will begin syncing to the Apple Health app after each successful device sync with the Garmin Connect app.
How Do I Enable or Disable Sharing With Apple Health?
To enable or disable sharing data from Garmin Connect to Apple Health, follow the instructions below.
Open the Apple Health app.
Select Summary (bottom left).
Select your Profile Picture (top right).
Select Apps and Services under Privacy.
Select the Connect app.
Toggle Categories on or off.
Once sharing is enabled, the Health app will only display previously recorded data from up to two weeks prior to the sharing being enabled.
If you have previously declined to share data with Apple Health, you may need to approve it from within the Connect app first by following the steps below.
Open the Garmin Connect app.
Select More.
Select Settings.
Select Connect Apps.
Select Apple Health under "Available Apps."
Select Connect with Apple Health.
Select the items that Garmin Connect can access.
Select Allow.
I Have Enabled Data from Garmin Connect to Be Shared But It Is Not Appearing in the Apple Health App
Data will only be sent to Apple Health while the Garmin Connect app is open in the foreground. If the app is closed or sent to the background, the transfer of data to Apple Health will not complete until a successful sync of the device while the Garmin Connect app is open.
Apple Health can also allow multiple sources to update your health data. When multiple sources are available, only one data source will be chosen based on the priority order listed in the Apple Health app. If you notice that your Garmin Connect data is not appearing in Apple Health but you have enabled sharing, you may need to update the priority of data sources so that Garmin Connect is first priority. For instructions refer to this Apple Support article: Prioritize data sources in Apple Health.
My Rings Are Not Updating in the Apple Health App
Movement rings are only presented in the Apple Health app if you had an Apple watch paired at one point in time. If you are now using a Garmin product to share data with Apple Health the rings will stop updating. The only way to update the movement rings in Apple Health is to sync an Apple Watch. For more information on Apple Health and the movement rings, contact Apple support.
