Replacement Watch Bands for the Approach S70
A replacement band can be ordered on Garmin’s website to update the look of your watch or replace a band.
The watch bands that fit your Approach® S70 - 42mm or Approach® S70 - 47mm watch can be found using the link below:
- Approach S70 - 42mm Replacement 20mm Watch Bands or QuickFit 20 Bands
- Approach S70 - 47mm Replacement 22mm Watch Bands or QuickFit 22 Bands
Finding Bands at Garmin.com
- Hover over the Sports & Fitness menu at the top Garmin.com.
- Select a product type.
- Select your watch from the list.
- Click on Accessories.
- Click on Bands.
You will now see a list of compatible bands for your watch.
If your watch is not listed here, you may need to use the search box located in the upper right-hand corner of the Garmin.com home page.
Looking for Help Installing Bands?
For help installing your Approach S70 watch replacement bands, see the related below.
