ecoRoute HD cable not pairing with the Camper/RV 660, dēzl™ 770, or dēzlCam™
There may be times when the ecoRoute HD cable will not pair with your device. Correcting this issue can be accomplished by following the steps below:
Update the device software
The software on your device can be updated using Garmin Express.
Set the transportation mode to automobile
Your device can only utilize the ecoRoute HD while in automobile mode. To set the transportation mode:
- Touch the vehicle icon at the top of the main menu
- Touch Car
- Touch Select
Enable the device's Bluetooth
For instructions enabling the Bluetooth, go to Pairing a Bluetooth phone with an Automotive device.
Pair the ecoRoute HD accessory
For instructions pairing the ecoRoute HD accessory, go to Pairing an ecoRoute HD accessory cable to a Garmin device.
Reset the ecoRoute HD accessory and device
If the ecoRoute HD accessory and device still aren't pairing, reset both using the instructions below:
- How to use the ecoRoute HD accessory reset button
- Hold the power button on the automotive device for 8-10 seconds
