My Approach G7 Is in the Wrong Language
If your Approach® G7 golf handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the device, follow the steps for resetting the device.
Changing the Language
From the Play screen, touch
Touch
twice.
Touch the second option from the bottom.
Select the language you want from the list.
You have now changed the language on your Approach G7 handheld.
