Installation Instructions for UltraFit Nylon Quick Release 22 MM Bands
After removing the existing band, follow the three steps below to attach your replacement nylon band to your watch.
Using two fingers, depress the spring loaded band pin to install each side of the band to the watch casing. The band pin will face the inside of the watch casing for both sides of the watch.
The inside adjustable part of the band should be adjusted in length based on the excess outside of the band once you have the watch snug on your wrist. If you have too much overlap from the outside part of the strap, increase the inside overlap to shorten the outside overlap.
The outside adjustable part of the band will feature an endcap with the Garmin logo on it. This side will be the side to adjust to tighten the watch after
