Changing Map Themes and Colors on a Garmin Automotive Device
Map Themes refer to the colors used for various mapping items, such as the map display background, highways, and major and minor roads. When a different Map Theme is selected, the colors change to more accurately reflect the colors that are commonly used in the selected area.
To Change the Map Theme:
  1. Touch Settings or the gear icon otr1010 settings wheel
  2. Touch Map Display
  3. Touch Map Theme
  4. Select the desired Map Theme
  5. Touch Save
The Map Theme will now be saved. Repeat these steps as needed.
