Apple: GPS Connections with iOS 14+
A privacy option of showing your exact GPS location or the surrounding location will be offered. If you find your GPS location is not correct or you are having trouble tracking, you may need to check your device Settings. Initially, upon opening the app after updating to iOS 14+ you will get a new Location pop-up asking if you would like to allow Boating to use your location. On this popup there is an option to turn ON or OFF precise location. This should be turned ON for the best results
If it is not selected initially, you can also access this through your device Settings by going to Boating > Location > Precise Location (toggle ON).
