Getting Started with the Xero A1, Xero A1i, and Xero A1i PRO
Black and white logo for xero products.
Before using your Xero® A1, Xero® A1i, or Xero® A1i Pro bow sight system, it is important to set it up properly. The following guide has some suggestions to help you get started. There are also some excellent videos available to watch for guidance in setting up your sight properly.
Installing Batteries
  • The device operates on two AAA lithium batteries. It is important to use lithium batteries as Alkaline and NiMH batteries do not meet the power requirements for auto-ranging functionality and may result in your device failing to operate properly.
  • Garmin recommends using Energizer Lithium batteries in all Xero sights. Lithium batteries are more reliable and are less likely to leak.
Mounting the Sight on Bow
Xero A1 & Xero A1i
Xero A1i Pro
Calibrating the Bow Sight
Before using your sight you want to calibrate it so the information it provides is accurate.
Xero A1 & Xero A1i
The first time you turn on the bow sight you are prompted to go through the initial setup steps.
  1. Select a language
  2. Select a unit of measure
  3. Select Yes to start the pin calibration procedure
  4. Select a ranged pin color (A1i only)
  5. If necessary, select Yes to adjust the pin and rangefinder reticle brightness and follow the on-screen instructions
  6. Setting the Primary Pin
  7. If further adjustments to primary pin are needed, see Moving the primary pin during calibration
  8. Select Done
  9. Align the rangefinder with the primary pin
  10. Select Done
  11. Follow the on-screen instructions to complete the pin calibration procedure and set pins for additional distances
Xero A1i Pro
  4. Follow the on-screen instructions to set the primary pin and calibrate the pin stack
