Replacement Watch Bands for Garmin Approach S62
A replacement band can be ordered on Garmin’s website to update the look of your watch or replace a band.
The watch bands that fit your Approach S62 can be found using the link below and expanding the + Bands line.
null
null
Replacing the Approach S62 Watch Band
Replacing the QuickFit band on your Approach S62 takes just a few steps. QuickFit bands are designed to be changed very quickly, and without tools.
Removing the Band
- Locate the latch on the band near the housing of the watch.
- Pull the latch away from the housing of the watch and lift the band from the pin
Replacing the Band
- Pull down on the latch on the band
- Place the band on the pin and release the latch
You have successfully changes your QuickFit band.
