(2023) Service Bulletin 22120 Rev D: GI 275 Multi-function Instrument System Software Version 2.60
PRODUCTS AFFECTED:
Garmin GI 275 Multi-function Instruments with System Software Version 2.53 or earlier are affected.
CERTIFICATION AUTHORIZATION:
TSO Authorization
TSO Authorization does not provide installation airworthiness approval. Separate installation airworthiness approval is required for type-certified aircraft. Notification of revision to any Garmin STC(s) will be provided under a separate service bulletin.
COMPLIANCE:
Optional: This Service Bulletin may be incorporated at the owner’s discretion.
PURPOSE:
GI 275 Multi-function Instrument System Software Version 2.60 provides the following updates:
NOTE
If installed, GTN Xi Software Version 20.30 (or later) and TXi Software Version 3.50 (or later) is recommended before loading GI 275 Software Version 2.60.
NOTE
Database sync routing is affected by this change. Systems with GTN™ 6XX/7XX (v6.72 or earlier) or GPS 175/GNC® 355/GNX™ 375 (v3.20 or earlier) interfaced to G500/G600 TXi (v3.50 or later) or GI 275 (v2.60 or later) no longer support database sync. Databases will need to be loaded onto each GTN 6XX/7XX and GPS 175/GNC 355/GNX 375 unit. This limitation will be fixed in future GTN 6XX/7XX and GPS 175/GNC 355/GNX 375 software versions.
  • Added the Miscellaneous Fields display to the HSI and HSI map pages
  • Added the ability to re-arm the optional 100ft / 30m Radar Altimeter aural callout for Rotorcraft Configurations
  • Improved the RP mode engagement button to top level menu
  • Improved the BT output data with various GPS sources
  • Added ‘No Coverage’ to the various FIS-B product legends
  • Improved the user experience for airspace information on the moving map page
  • Added digitally signed database application
  • Added a new discrete Lo Input configuration option for Main Power Failure messages
Sumber terkait
