When Connected to a Mac, These Devices Will Only be Recognized or Detected by one Application at a Time
For example, if Garmin Express is open and has detected the device, opening Garmin BaseCamp™ software at the same time will result in BaseCamp being unable to find the device until both applications are completely closed and the desired application is re-opened.
NOTE: Devices with MTP Mode are prevented from appearing as a separate drive on a Mac computer. For these devices, a Windows computer must be used.
To Force Quit Garmin Express or Garmin BaseCamp on Mac:
- Press Command + Option + Escape on the keyboard
- Select Garmin Express or Garmin BaseCamp™ from the list of applications
- Click Force Quit
Note: A second set of instructions may be required to force quit Garmin Express.
- Select the Triangle icon in the upper right corner and click Quit
- Click Quit again
The Garmin Express or Garmin BaseCamp program will now be closed.
To Keep Garmin Express From Opening when the Computer is Powered on or when a Garmin Device is Connected to the Computer:
- Click on Garmin Express by the Apple icon
- Click Preferences or Settings
- Remove the check mark from the following boxes:
- "Always keep Garmin Express running in the background."
- "Automatically launch Garmin Express when a Garmin device is connected."
Note: Removing the check marks will disable the ability for Garmin Express to automatically launch and perform syncs to a device using Garmin Connect.
Restart the computer after making these changes.
