Changing the Owner on a Consumer inReach Account
There is no option to transfer or change ownership of a Consumer inReach® account to another individual. When creating an inReach account, there are specific terms and conditions that must be agreed to before you can proceed with the activation and use of inReach products and services. For this reason, the account is intended to have a single owner whose information is entered at the time the account is created.
For families or groups of individuals who need to use devices simultaneously, the only option is to activate any additional inReach devices under their own consumer account (i.e. one inReach device per Garmin Explore™ account). When doing this, keep in mind that each account needs to be under a different email address.
Changing the email address on an account does not change account ownership. If there is a need to transfer ownership we recommend canceling the service and resetting the inReach device so that the new user can then create a separate account using their own information. Some examples of when service must be canceled include, but are not limited to:
When preparing to sell an inReach device.
Gifting an inReach device to a friend, relative, or spouse.
If you are only temporarily lending out your inReach device to someone, refer to the following FAQs for more details and recommendations:
NOTE: Canceling service may incur fees for early termination, and additional fees to activate again later. If an account was mistakenly set up under the wrong individual's information, such as when helping a friend or family member with a new device, contact Garmin Services Billing to discuss your options. The process for canceling your service is the same whether the inReach is suspended or active.
Select MANAGE on the subscription you want to cancel.
Select CANCEL PLAN.
If you are currently on an Essential, Standard, or Premium plan you will be prompted with an option to switch to an inReach Enabled plan or suspend service.
Select CONTINUE WITH CANCEL.
Select CANCEL IMMEDIATELY when prompted to finalize cancelling service.
Sending a Cancellation Request via Email
If you are unable to access your account you may send your request to GarminServicesBilling@garmin.com. The request must state that you wish to cancel service, and also include the following:
Email address the service is under
Billing address of the credit card used on the account
IMEI number of the device
Failure to submit the proper information can delay implementation of your Cancellation.
Requests of Cancellation will be processed and become effective within 2 business days of submission. Garmin is closed on weekends and holidays.
Resetting an inReach Device
Steps for resetting the device will vary by model.
Alpha® 200i or Alpha® 300i Handheld
Resetting the Alpha Handheld
From the main menu, select Setup.
Select Reset.
Select Delete All.
The Alpha handheld will reboot. Hold down the Power button to power the down the device.
Additional Steps for the Garmin Messenger™ App
If you have used the Garmin Messenger app and wish to receive an future inReach messages in your phone's default text messaging app instead of the Garmin Messenger app, you will also need to remove your phone number in the Garmin Messenger app using the steps below:
Open the Garmin Messenger app.
NOTE: If you already uninstalled the Garmin Messenger app, reinstall it and follow the prompts to verify your phone number again.
Select the profile icon or in the top left.
Select Accounts.
Select Manage Garmin Messenger Account.
Select Delete Garmin Messenger Account.
Select Delete Account.
inReach SE® or inReach Explorer® Satellite Communicator
Turn on the inReach handheld.
Select Settings.
Select Restore Factory Settings.
Select Reset.
The inReach handheld will reset and reboot to the activation page. Hold down the Power button to power down the device.
inReach SE®+ or inReach Explorer®+ Satellite Communicator
Select Settings.
Select Recovery Options.
inReach® Messenger or Messenger Plus Satellite Communicator
Resetting the inReach Messenger or Messenger Plus
From the home screen, press or to scroll through the main menu.
Select SETTINGS.
Select System .
Select Reset.
Select Delete Data and Reset Settings.
The inReach Messenger will reset and reboot to the activation page. Hold down the Power button to power down the device.
If you wish to receive an future inReach messages in your phone's default text messaging app instead of the Garmin Messenger app, you will also need to remove your phone number in the Garmin Messenger app using the steps below:
Select Accounts.
inReach® Mini Satellite Communicator
From the home page, press OK to open the main menu.
Select Setup.
Select Restore Defaults.
The inReach Mini will reset and reboot to the activation page. Hold down the Power button to power down the device.
inReach Mini® 2 Satellite Communicator
Resetting the inReach Mini 2
Select Settings.
Select System.
Select Reset Device.
The inReach Mini 2 will reset and reboot to the activation page. Hold down the Power button to power down the device.
Select Accounts.
GPSMAP® 66i, 67i, 86i, or 86sci Handheld
Resetting the GPSMAP Handheld
Power the handheld on.
Press MENU twice to access the main menu.
Select Setup.
Select Reset.
Select Delete All.
Select Reset.
The handheld will reset and reboot to the activation page. Hold the Power button to power down the handheld.
Select Accounts.
Montana® 700i or 750i Handheld
Resetting the Montana Handheld
After canceling service, have the new user visit the Garmin Explore website to create or sign into their own Garmin account for activating their inReach service. For detailed steps, see Related.
