TopoActive Maps on the eTrex 22x/32x
The eTrex® 22X and eTrex® 32x are preloaded with TopoActive mapping, which includes features and benefits optimized for outdoor activities.
What Are the Features Included in TopoActive Maps?
Routable roads, trails, and walking paths; international boundaries, waterways, natural features, land use areas, historical sites, airport structures, buildings, and more. TopoActive maps will not supply turn-by-turn routing in automotive routing profiles.
Loaded with thousands of points of interest, including shops, restaurants and bars, car parks, schools and universities, and accommodations.
Contour line information varies based on location and the detailed information that OpenStreetMap has for that area. For example, contour or elevation lines are at roughly 100ft intervals for the North America TopoActive map. Other regions may use a shaded relief map and contain no contour lines.
TopoActive mapping will include any fire trails that are present in OpenStreetMap (https://www.openstreetmap.org). Many fire trails are included, but we cannot speak to their completeness. They will appear as unpaved roads on the map.
While there are many points of interest searchable with the installed TopoActive mapping, there is no address search function.
The quality of the coverage will depend on the region. Urban areas will typically be more developed while coverage in rural areas may not be very good. TopoActive Maps are a Garmin OpenStreetMap Product.
What Coverage Is Included With TopoActive Maps?
Coverage of preloaded TopoActive Maps is based on where the Garmin device was purchased. For example, if purchased in the United States it will come preinstalled with TopoActive North America.
North America
Coverage for North America is comprised of three different region files: Canada and Alaska, United States (all U.S states except Alaska), and Middle America (South of the U.S. border).
Europe
Coverage for Europe is comprised of three different region files:
TopoActive Western Europe: Includes Andorra, Belgium, Ceuta, Faroe Islands, France, Iceland, Luxembourg, Netherlands, Melilla, Portugal, Spain, and United Kingdom.
TopoActive Central Europe: Includes Albania, Austria, Bosnia and Herzegovina, Croatia, Czechia, Denmark, Germany, Greece, Italy, Kosovo, Macedonia, Montenegro, Slovenia, and Switzerland.
TopoActive Eastern Europe: Includes Armenia, Azerbaijan, Belarus, Bulgaria, Cyprus, Estonia, Finland, Georgia, Hungary, Russia (Kaliningrad), Latvia, Lithuania, Moldova, Norway, Poland, Romania, Slovakia, Sweden, Turkey, and Ukraine.
South America
null
Africa
Coverage for Africa is comprised of two different region files:
TopoActive Africa North: Includes Algeria, Benin, Burkina Faso, Cameroon, Cape Verde, Central African Republic, Ceuta, Chad, Côte d’Ivoire, Dijbouti, Eritrea, Egypt, Ethiopia, Gambia, Ghana, Guinea, Guinea-Bissau, Liberia, Libya, Mali, Mauritania, Melilla, Morocco, Niger, Nigeria, Senegal, Sierra Leone, Somalia, South Sudan, Sudan, Togo, and Tunisia.
TopoActive Africa South: Includes Angola, Botswana, Burundi, Comoros, Democratic Republic of Congo, Equatorial Guinea, Gabon, Kenya, Lesotho, Madagascar, Malawi, Mauritius, Mayotte, Mozambique, Namibia, Republic of Congo, Réunion, Rwanda, São Tomé und Príncipe, Seychelles, Somalia, South Africa, South Sudan, Swaziland, Tanzania, Uganda, Zambia, Zimbabwe, Saint Helena, Ascension and Tristan da Cunha, and Bouvet Island.
The following examples show what the map can look like at different zoom levels.
NOTE: Detail and coverage may vary depending on the region you are using it in.
Comparison of TopoActive and Topo 100K
The following examples show a comparison of what the new US TopoActive mapping can look like compared to the US Topo 100K.
NOTE: Example images are taken from BaseCamp™ software and may have a slightly different appearance on your device.
US Topo 100k
US TopoActive
Routing With the TopoActive Map
TopoActive mapping is routable and can give calculated, lock-on trail or street, turn by turn guidance to a destination.
This map has multiple routing options available.
While TopoActive mapping will provide road and trail navigation for Pedestrian and Bicycle routes, it will only give straight-line navigation when routing is set for Car/Motorcycle or Off Road. The TopoActive mapping is based on OSM (OpenStreetMaps) that have not been verified safe for automotive driving. Also, the option for navigating to an address is not available with this map.
Changing Routing Settings on an eTrex 22x/32x Handhelds
Press menu twice to access the main menu.
Select Setup.
Select Routing.
Select Guidance Method to choose Off Road (straight-line) or On Road (turn by turn) guidance.
Select Calculate Routes for to change the activity used for route calculations.
OpenStreetMap Details
OpenStreetMap (OSM) is developed and added to by community mappers around the world. OSM is a highly detailed dataset. In many rural areas of the world, OSM has medium-to low-detailed data. Features are added and edited by community members with local knowledge. Coverage of features may vary and includes geographic locations, place names, landmarks, points of interest, hydrographic features, and land-use/land cover. OSM is an open data source. OSM also includes an open data source elevation dataset. The scale is not consistent because the OSM data is Volunteered Geographic Information. Scale detail can vary from 1:24K or better in major urban areas to much higher scales in more rural areas.
You can contribute to this database for future releases by adding, updating, editing and commenting:
Follow the outlined steps for becoming a contributor.
If you prefer not to map the updates, you can add a comment at the location that needs reviewing and other contributors will review, investigate and apply the update when appropriate.
