Alpha 200 Plus and Alpha 300 Series Channel View
The Alpha® 200 Plus, Alpha® 300, and Alpha® 300i dog tracking handhelds have a feature called Channel View. Channel view allows you to see what device ID numbers are being used that are within range of you. This allows you to identify and change your ID numbers to avoid potential interference.
Using Channel view
- From the Main Menu Select Channel View
- You will see the following screen
- Select the desired channel to see what ID's are used.
- Select a used ID to change that ID number
- Select Yes. The Alpha will begin to scan for a clear ID number
- When the handheld finds a clear ID , you will see the following screen
- Once the handheld finds a clear ID you will see the following screen
NOTE: If the collar is paired to another handheld you will need to change the on all other handhelds.
