Expert Assist: Setting Up a Target
When working with Expert Assist, the user needs to have a Target loaded and configured properly. Any of the default JL Audio Target files can be used and modified if desired. Targets can be loaded by selecting "Targets" on the right-hand side of the interface, then selecting "Load" at the bottom right corner in the Targets Panel. If a Target is modified, it can also be saved from that same place. The user should also ensure that there are no linking dots engaged on the Targets before beginning.
For more information on how to load or create a Target, click here.
Sumber terkait
