How to Read Your Training Status Report in Garmin Connect
The Training Status report in the Garmin Connect™ program is designed to show various training metrics, including VO2 Max, Exercise Load, the 7-Day Total Training Load, current Training Status, and current Training Load Focus. The Training Status report will only display the information metrics that were actually measured by your selected device for the selected period. You can customize the report to display 4-week, 6-month, or 1-year periods. If there were multiple devices associated to your account for a selected period, you can select a specific device to display its data.
NOTE: Although the Exercise Load and VO2 Max measurements remain the same regardless of which device you select, the 7-Day Training Load, Training Status, and Training Load Focus measurements will display only those values that were measured by the selected device.
Training Status Report With No Status
If you select a device and a timeframe during which time the selected device did not measure any Exercise Load and also did not measure a Training Status, the Training Status report may show as empty.
Garmin Connect Displays No Status for Training Status
Training Status for Unified Training Status Capable Devices
If you do not have more than one unified training status capable device, you will no longer have the device selector drop down menu when viewing your reports. For information on unified training status capable devices see What is Unified Training Status?
No Drop Down for Training Status Reports
Training Status Report For a Selected Device and Selected Time Period
If the selected device measured both Exercise Load and a Training Status during the selected period, your Training Status, Training Load, and 7-Day Total Training Load will populate. If you run frequently with a wearable device capable of measuring a VO2 Max, you will often see the Training Status report populate.
Training Status in Garmin Connect showing Productive
Training Status Report Showing No Status or Detraining Status
If you own only an Edge® cycling computer but do not use a power meter, you may see a Training Status report infrequently at times when your Edge device actually measures a Training Status. Edge devices that do not have a paired power meter, however, can only report a Training Status when the device measures a “No Status” or “Detraining” status. This may occur after periods of a week or more without any activities.
Training Status Section of Garmin Connect showing No Status
Sumber terkait
