Getting Started with Garmin OnDeck
Select a topic for more information:
In addition to the information in this FAQ, below is a short video that covers how to get the OnDeck™ system running, activating the subscription, and covers configuring switches and more:
General Overview of Installation of the GTB 10 OnDeck Hub, Features, Capabilities & What's Included
Once installed, the GTB 10 OnDeck Hub works with the Garmin ActiveCaptain app, and requires a monthly or annual subscription¹. The GTB 10 OnDeck Hub Installation Instructions also provides guidance for properly installing the OnDeck Hub. In addition to this documentation, a short video below provides additional guidance:
The OnDeck Hub can then be used to track & monitor vessel position or movement, with information such as vessel speed, vessel maximum speed over time, moving average speed and more. The OnDeck Hub will also control up to 5 relayed switches², and provide status alerts & notifications to ActiveCaptain, on up to 30 security sensors.
When connected to a network with a compatible Garmin Chartplotter³ via Marine Network, the vessel operator will have on the water control over the same relayed switches managed in ActiveCaptain.
With ActiveCaptain, the GTB 10 OnDeck Hub can be used to remotely monitor the status of various accessories, such as security sensors, shore power status, battery voltage(s), GPS heading of the vessel, temperature on the vessel and more.
Beyond monitoring vessel status, ActiveCaptain can be setup to alert the vessel operator if the vessel moves beyond a designated boundary (geo-fence), if the temperature becomes excessively hot or cold, if the battery voltage is too low, if the bilge pump remains active for more than 5 seconds, or if the security sensors have been activated.
The GTB 10 OnDeck Hub 4 includes 1 of the following of each:
    • Security sensor
    • Temperature sensor
    • Shore power sensor
    • Relay switch 12 Vdc
    • In/Out data cable (19-pin) for monitor sensors and relay status
1 The subscriptions available utilize 3G or 4G cellular data and are available only through Garmin in monthly or annual plans. The purpose of this cellular data connection is for relaying system status alerts/notifications, as well as to remotely enable or disable relayed switches. The cellular connection cannot be used to remotely control or view the chartplotter, and it cannot be used to view wired or wireless cameras.
NOTE: Garmin's agreement with cellular providers allows the OnDeck Hub to seamlessly connect to all AT&T, T-Mobile, Sprint & Verizon's 3G & 4G data networks.
2 The GTB 10 OnDeck Hub is bundled with a 12Vdc relay switch. Switching for 24Vdc systems requires part number: 010-13009-0. For a list of what is included with the GTB 10 OnDeck Hub, see General Overview of Installation of the GTB 10 OnDeck Hub, Features, Capabilities & What's Included .
3 A compatible Garmin Chartplotter must be configured for wireless access at the time the OnDeck hub is plugged in for first use; otherwise the GTB 10 OnDeck hub's wireless network will need to be configured as if it were a stand-alone product. If the OnDeck Hub is on the network with one or more Garmin Chartplotters, it will serve as the host, be the main wireless access point. There is no way to prevent the GTB 10 from serving as the main access point.
4
The GTB 10 also includes the GTB 10 OnDeck Hub itself, a power cable, Garmin Marine Network cable, a NMEA 2000 drop cable, and NMEA 2000 T-connector.
NOTE: To see compatible chartplotters view Compatible Garmin Chartplotters & Enabling/Disabling Digital Switches with a Garmin Chartplotter
General Information
The subscription based GTB 10 OnDeck Hub utilizes *cellular 3G & 4G technology and features a built-in GPS receiver, integrated Garmin Marine Wi-Fi, a Garmin Marine Network port, a NMEA 2000 port, and a 19-pin In/Out data cable for monitoring, tracking, and controlling various systems remotely or even while on board the vessel. All functions can be monitors, tracked and controlled via ActiveCaptain, while some functions such as controlling relay switches can also be controlled using a compatible Garmin Chartplotter.
The GTB 10 OnDeck Hub has the following features:
      • Enables the vessel operator to remotely enable/disable and monitor the status of up to 5 devices total, and includes one 12Vdc relay switch
        • Supports 24Vdc relay switch(es)
        • Up to 5 devices can be used to remotely enabled or disabled via relay switch(es)
        • Relay switches can also be enabled and disabled via a compatible Garmin Chartplotter
      • Supports up to 30 different security sensors
        • Security sensors connect up in series
      •  Smart battery and power saving features:
        • Prevents over discharging of the battery source on both 12Vdc & 24Vdc systems
        • Built-in internal battery (lasts up to 48 hours) is switched on to run if the vessels charging system it is not in a full-power state and the voltage of the external power input drops to < 11.9V for a 12V system or < 23.8V for a 24V system
        • The system type is determined by the voltage of the external power input: < 15V for a 12V system and > 18V for a 24V system
        • The OnDeck Hub switches back to running from the external power input when it rises to >= 12.4V for a 12V system or >= 24.3V for a 24V system
        • The internal battery lasts about 48 hours under typical use
        • The OnDeck Hub when powered off can consume up to 7mA of power
What's included
        • Security Sensor
          • Included security sensor wires up to the In/Out 19-pin data cable
          • Up to 29 additional security sensors can be purchased separately
        • Temperature Sensor
          • Included temperature sensor wires up to the In/Out 19-pin data cable
          • Additional temperature sensors will need to be NMEA 2000
        • Shore Power Sensor
          • Included shore power sensor wires up to the In/Out 19-pin data cable
        • 12Vdc Relay Switch
      • In/Out 19-pin data cable where the following devices interface:
        • Up to 5 User Controllable Relay Switches
          • Relay 6 is to be used with a switched relay to automatically power on or off a Garmin Marine Network Device by the GTB 10 On Deck Hub
            • Some Marine Network Devices can or may be powered by a 24Vdc system, if this is the case, a 24Vdc relay switch is required
          • Relay 7 is to be used with a switched relay to automatically power on or off (a) NMEA 2000 (devices)
            • Devices not desired to be powered on by the GBT 10 OnDeck Hub will require a NMEA 2000 power isolator, and an additional NMEA 2000 power cable
        • Bilge Pump 1
        • Bilge Pump 2
        • Up to 30 Security Sensors
          • Connected in Series
        • Power Monitoring for pp to 2 Batteries
        • For complete installation instructions, see the GTB 10 OnDeck Hub Installation Instructions manual
NOTE: Not all sensor data monitored remotely via cellular is not relayed in real-time. In full power mode, notifications and status alerts are relayed every 15 minutes; and in a low power mode, data is relayed every 30 minutes. Urgent sensors such as Shore Power, Security Sensors, & the Bilge Pump (if run for over 5 seconds) will trigger a real-time data upload for an immediate notification/status alert to appear in ActiveCaptain.
Compatible Garmin chartplotters can be networked via Garmin Marine Network or NMEA 2000 to enable and disable up to 5 of the 12Vdc or 24Vdc accessories/devices interfaced with the GTB 10 OnDeck Hub.
The GTB 10 OnDeck Hub is compatible with the following Garmin Chartplotters
      • GPSMAP® 7x2 chartplotter series
      • GPSMAP® 7x2 Plus chartplotter series
      • GPSMAP® 7x3 chartplotter series
      • GPSMAP® 9x2 chartplotter series
      • GPSMAP® 9x2 Plus chartplotter series
      • GPSMAP® 9x3 chartplotter series
      • GPSMAP® 10x2 chartplotter series
      • GPSMAP® 12x2chartplotter series
      • GPSMAP® 12x2 Plus chartplotter series
      • GPSMAP® 12x2 Touch chartplotter series
      • GPSMAP® 12x3 chartplotter series
      • GPSMAP® 7400 chartplotter series
      • GPSMAP® 7600 chartplotter series
      • GPSMAP® 8400 chartplotter series
      • GPSMAP® 8600 chartplotter series
      • GPSMAP® 8700 Black Box
      • Volvo Penta Glass Cockpit System
Before you can use the OnDeck Hub relay switches from a chartplotter, configuration is required. First go to Settings > My Vessel > Switching > OnDeck Hub.
Going forward, OnDeck Hub relay switches can be controlled from a Garmin chartplotter by selecting Home > AV, Gauges, & Controls > Switching to access all switches.
If the OnDeck Hub switches are not present, select Menu > Setup to edit the current page or add a new one.
NOTE: Software must be up to date. See section below for instructions.
Registering, Updating and Pairing the GTB 10 OnDeck Hub
Registration of the GTB 10 OnDeck Hub is automatically done when paired with ActiveCaptain, and can also be done using Garmin Express by following the instructions in Registering Garmin Marine Devices and Charts.
Updating the GTB OnDeck Hub's software must be done with a Garmin Chartplotter, by following the instructions in  Garmin Marine Device Software Updates, and the update may be done or acquired via one of the following methods:
General Information & Basic Troubleshooting of Data Reported via 3G/4G to ActiveCaptain
Data is reported every fifteen minutes while the OnDeck Hub is operating in a full power state. This data will be resent every thirty minutes while the OnDeck hub is operating in standby mode. This includes data about the current status of the bilge pump, see note below.
To get the most recent data, in the ActiveCaptain app from the Sensors, Switches, or Tracking & Security page, swipe down in in ActiveCaptain app while in the OnDeck view. A manual refresh of data from the OnDeck Hub will be loaded. It is important to note that the serve will limit how often a user may request a manual data refresh.  This limit does not prevent the OnDeck hub from automatic reporting data.
If data is not available in the ActiveCaptain app, or is significantly out of date, and a refresh didn't help, try the following:
    1. Verify that OnDeck is turned on by pressing power button.  If status LED first turns red, device was off.  If status LED first blinks green, device was in standby
    2. Verify that OnDeck has valid input power that has not been detected as a drained battery
    3. Check subscription status through website
    4. Check that Vessel Owner on boat matches user logged into the ActiveCaptain app
    5. Connect the smart device to OnDeck Wi-Fi and check signal strength (ActiveCaptain: Settings > OnDeck Diagnostics) and that internet is available
      • Check that vessel is located in a location with cellular coverage
      • Adjust antenna / device placement & orientation per installation manual
    6. Connect smart device to OnDeck Wi-Fi and wait for the prompt to transfer login credentials then agree / accept prompt.
NOTE: The bilge pump will only show as running if it is on exactly when data is collected.  To verify operation, force the pump to stay running for an extended period of time while performing a data refresh in the ActiveCaptain app. To perform the refresh, in the ActiveCaptain app select the Sensors, Switches, or Tracking & Security page, and then swipe down to start a manual refresh of Telematics data from the OnDeck Hub.
