Importing and Sending GPX Files onto a zūmo XT2 GPS Navigator
GPX files (saved locations, routes, tracks) can be transferred or synced to the zūmo® XT2 GPS navigator in a variety of ways. See the options and steps included below.
Importing and Syncing Files with Garmin Explore™
The Tread® App is the best option to wirelessly sync data with the zūmo XT2. Route creation is not a supported feature on the Garmin Explore website for the zumo XT2. If you prefer to use a computer with the Garmin Explore website and not the Tread app, it is required to first do the initial setup using the Tread app. Once the setup is completed, you can use the same account to sign into the Garmin Explore website. Information added or deleted from the Garmin Explore account on the website or Tread app will be added or removed from the zūmo XT2 the next time it syncs. If your smartphone does not have an active internet connection, it will not be able to sync. See the Owner's Manual of your device for instructions to sync data from your device with your Garmin Explore Account.
See the detailed video below for more info on using Garmin Explore data with the zumo XT2.
Tread App:
See Syncing, Adding, and Deleting Garmin Explore Data on the zūmo XT2 GPS Navigator.
NOTE: When using the zūmo XT2, it is recommended to use the Tread app for creating and managing waypoints, routes, and tracks. If an internet connection to sync the data from the Tread app on your phone is not available, you can share the GPX file first to the Tread app and then send it directly to the zūmo XT2 as long as you are connected to the Tread app via Bluetooth.
Garmin Explore™ Website
See Importing Waypoints, Routes, and Tracks Into the Garmin Explore Website.
NOTE: The Garmin Explore website can be used to manage waypoints and tracks, but does not support route creation for the zūmo XT2.
zumo XT2 Sharing Options:
See Sharing Routes and Tracks from a zūmo XT2 with Other zūmo Users.
Sending GPX Files Using the Garmin Tread App:
- Open the Tread App
- Select the Menu icon
- Select Explore Library
- Choose a file and select the “Share GPX” option
- Use the sharing options on your phone to share the GPX file
The receiving user can then open the file with the Tread app.
Transferring GPX Files From Your Computer to Your zumo XT2:
See the steps in Transferring GPX Files From Your Computer.Transferring GPX Files From the Computer to a Memory Card:
- Format a new memory card card.
- With the memory card inserted, connect the zumo device to a computer.
- On your computer, locate the zumo device drive with the Memory Card.
- Open the Memory Card drive, and create a folder named GPX.
- Drag and drop the GPX file(s) into the GPX folder on the memory card,
The files will now be on the memory card.
Importing GPX Files From a Memory Card to the zumo XT2 Device:
- From Explore on your device, touch the 3 dots in the upper right.
- Select Import.
- Select from the file locations.
- Touch OK.
- Select the items to be imported (ex. Waypoints, Routes).
- Touch Next.
- Select a collection or create a New Collection to add the imported data, if desired.
- You will be prompted to name the new collection.
- Touch Import
The files will now be saved on the zumo XT2.
