Using Routes on the Rino 600 Series
A route is a sequence of points that leads you to your final destination.
Creating a Route
  1. From the main menu, select Route Planner.
  2. Select <Create Route>.
  3. Select <Select First Point>.
  4. Select a category.
  5. Select the first point in the route.
  6. Select Use.
  7. Select <Select Next Point>.
  8. Repeat steps 4-7 until the route is complete.
    NOTE: A route must contain at least two points.
  9. Select Back Arrow to save the route.
Editing the Name of a Route
  2. Select a route.
  3. Select Change Name.
  4. Enter the new name.
  5. Select Green Checkmark.
Editing the Points in a Route
  2. Select a route.
  3. Select Edit Route.
  4. Select a point.
  5. Select an option:
    • Review: Shows the point on the map.
    • Move Up/Move Down: Changes the order of the point in the route.
    • Insert: Adds an addition point ahead of the selected point in the route.
    • Remove: Removes the point from the route.
  6. Select Back Arrow to save the route.
Viewing a Route on the Map
  2. Select a route.
  3. Select View Map.
Deleting a Route
  2. Select a route.
  3. Select Delete Route.
  4. Select Yes.
Viewing the Active Route
  1. While navigating a route, select Active Route from the main menu.
  2. Select a point in the route to view additional details.
Reversing a Route
  2. Select a route.
  3. Select Reverse Route.
