Truck Types Supported by the Garmin eLog
The Garmin eLog™ Compliant ELD will function with and transfer information through most trucks which have an On-Board Diagnostic (OBD) port with a 9-pin J1939 configuration. The Garmin eLog includes a 6-pin J1708 adapter cable for trucks with a 6-pin configuration. Garmin eLog ELD supports both 250kbps and 500kbps baud rates, depending on which baud rate your truck is equipped with.
More Compatibility Information:
  • The Garmin eLog ELD is not compatible with vehicles using the OBD-II protocol (SAE J1979).
  • Volvo Trucks with a Volvo engine and 16-pin J1962 configuration will require a 16-pin to 9-pin adapter cable.
    • This cable is not sold by Garmin but can be found online.
    • Only this cable has been tested to work properly with the Garmin eLog.
    • 16-pin J1962 configurations requiring this adapter are only tested to be supported with Volvo engines.
    • Volvo Trucks using a standard 9 pin or J1939 configuration are compatible and do not require any additional adapter cables.
  • Trucks with an RP1226 diagnostic port will require an RP1226 to J1939 Type 2 adapter cable.
  • Hino trucks are unsupported at this time.
  • 2016 and Newer PACCAR/Peterbilt/Kenworth Trucks will require a 9-pin to Y cable adapter.
  • All other port configurations and truck types have not been confirmed as compatible and may not be supported by the Garmin eLog ELD.
    • Incompatible port configurations and truck types may result in malfunctions, missing data, and errors in the data recorded by the Garmin eLog ELD.
Sumber terkait
