Showing Saved Activities and Tracks on the Map of the Montana 700 Series
The Montana® 700 series outdoor handhelds can show both recorded activities and saved tracks on the map.
By default, the Recording Controls tool will record the track as an activity, which is saved under Recorded Activities. If desired, activities can also be converted into a traditional track-based GPX file format, which will be saved under Saved Tracks. For more details see Creating a Track from a Saved Activity and Advanced Recording Settings - Output Format.
NOTE: If your recorded activities do not have an option to Show or Hide on Map, you need to update the software on your handheld. For detailed steps, see - Installing Software Updates to Outdoor/Marine Handhelds
Showing an Activity or Track on the Map
Showing a Recorded Activity on the Map
  1. Touch Home to access the main menu.
  2. Select Recorded Activities.
  3. Select a saved activity.
  4. Toggle on Show on Map.
Now while on the Map page, the activity will appear.
Showing a Saved Track on the Map
  2. Select Saved Tracks.
  3. Select a saved track.
    • Additional steps for archived tracks:
      1. Select Archived Tracks.
      2. Select the track you want to change.
      3. Touch Gray Star.
Now while on the Map page, the track will appear.
NOTE: For the Montana 700i, 710i, 750i, and 760i handhelds, the activity and track recording settings described above are different and separate from the Tracking tool that uploads track data via the inReach® subscription to a LiveTrack™ page or MapShare™ page, the explore.garmin.com website, and Garmin Explore™ app. For how to use the Tracking features and additional helpful articles, see Related .
For information on your specific device, see the Owner's Manual.
Changing the Track or Activity Color
  2. Select Saved Tracks or Recorded Activities.
  3. Select a saved track or recorded activity.
  4. Select Lowercase i.
  5. Select Color to select the color for the track or activity
Sumber terkait
